sawilder
Member Since 16 May 2013
Offline Last Active Oct 04 2013 12:40 PM
In Topic: Help with my Whirlpool Refrigerator
03 October 2013 - 07:58 PM
Thank you all for your help!  Hope this will fix it.
03 October 2013 - 02:35 PM
Is the Gemini board replaceable?  What parts do I need to fix this?  Thanks!
03 October 2013 - 11:53 AM
I have not removed any wiring harnesses.  The problem keeps getting worse.  Now the computer screen won't come on at all, the ice bucket light does not come on, and the ice dispenser motor does not work.
02 October 2013 - 07:24 AM
I found the Control Board Troubleshooting sheet, and ran through the list.  The door switches were ok.  The Icemaker fill test did not work at all - no water.  Also the Ice Level Sensor said the bin was full when it was empty.  I noticed a small amount of condensation around the icemaker outlet, but nothing that would block things or interfere with the seal to the door.  There was a droplet or two that had frozen at the bottom of the cover, but when I opened the gate it didn't feel very cold in there, definitely not freezing.
Suggestions?
01 October 2013 - 09:26 PM
Thanks for your reply, but the door switches work fine.  We tried them already.
