WalterG7712
Member Since 20 May 2013
Offline Last Active Mar 11 2015 11:22 PM
#313108 Whirlpool WFW9250WW01 f6e1 error add a garment light stays on
Posted by WalterG7712 on 10 February 2015 - 08:54 AM
Walter, techs as opposed to Diyers, should take the initiative and search the site for answers. Then the brethren here can further provide assistance... you should learn to use the wealth of information first.
If you searched the forums for "whirpool f6 e1" There is information already at this site that may help.
have you searched the dl section for a tech sheet or requested one in the proper forum?
If unable to find anything helpful or need some further explanation, we will be glad to help. Remember, for techs, this site is a workshop/learning academy, not just a tech help line.
A tech may come along and provide you with ideas/help and it takes me longer to write this response than it would to simply provide you with an answer. However just giving you the info will actually be a disservice to you.
Appliantology has an absolutely amazing wealth of information and usually someone has already experienced and talked about your issue... seek it out, read responses and the discussions and watchyour knowledge in the trade grow exponentially.
If you have any questions about searching this issue, let me know, then together we can search the site and discuss the gems of wisdom on your subject provided by the masters in previous threads.
Thanks Durham,
  I had searched the site before I posted but was having trouble finding something I hadn't checked. I did find a tech sheet and video on cleaning the board connections at ccu and mcu, after I posted.
   I will double check the wires and connectors when I go back.
#303459 Mle 2000ayw
Posted by WalterG7712 on 16 September 2014 - 06:07 PM
Went back today. Both water valves were on, but connector for hot water wasn't attached properly.
Thanks
#299501 Frigidaire refrig FGHB2844LF
Posted by WalterG7712 on 24 July 2014 - 06:17 PM
Found a crack in the plastic ice tray. It was leaking a little each time and freezing in the ice bin. Then the auger didn't work.
#299391 Frigidaire refrig FGHB2844LF
Posted by WalterG7712 on 23 July 2014 - 08:06 AM
Got it!!!!! Thanks, didn't know I could search that way.
#298108 LG DLEC855R Dryer service manual
Posted by WalterG7712 on 07 July 2014 - 05:27 PM
Sorry meant to post the fix. Error was te3. Info from LG said to test thermister but the dryer had a resetable thermostat.
#280350 Samsung Rs267LBSH
Posted by WalterG7712 on 07 January 2014 - 09:22 AM
Noise ended up being some ice around the fan blade in the freezer. Thawed and checked def heater etc then ordered sensor. Refrigerator side started warming up while I waited on parts. Ended up replacing the defrost heater in refrig. side. Everything working well.
Thanks for your help.
