jbeckman713
Member Since 22 May 2013
Offline Last Active Today, 10:29 AM
In Topic: Help Selecting A New VOM For Appliance Repair?
21 August 2014 - 08:20 AM
I have been looking at the Fluke 233. anyone have any experience with this meter? I like the removable head for remote readings.
http://www.fluke.com...t.htm?PID=69170
In Topic: RoperElecDryerRED4440VQ1 No Start
06 June 2014 - 10:40 AM
Is your power to the motor? Check your push to start switch also.
In Topic: Maytag Epic Dryer turns on, controls work, beeps, but no go?
26 March 2014 - 11:42 PM
If you have the correct power, thermal fuse,  thermal cutoff, belt switch and door switch are testing ok you need a tech to come and run some tests with your control board to determine if a new one is necessary.
26 March 2014 - 11:17 PM
Part number: 8558455
26 March 2014 - 10:17 PM
Just messin with ya....If you have the door shut how do you know the light is off? Get it? :woot:
I would still check continuity of the door switch
