gecustomer
Member Since 25 May 2013
Offline Last Active May 26 2013 04:46 PM
In Topic: frost buildup in GE Arctica refrigerator
26 May 2013 - 03:10 PM
Ok, i managed to pull some slack and deep it into ice water. It has settled at 15.7K.
26 May 2013 - 02:51 PM
Also I have to cut the wires to take the thermistor out to test it.
26 May 2013 - 02:47 PM
I measured the thermister right on the evaporator when the freezer was cold. It is 23K-ohm. then I heated up with hair dryer, and went don to 8K-ohm, and started to rise slowly. so is this a good test or I have to isolate it and do the ice water test
also, you said water gets in the thermister and raises the resistance, but the higher the resistance means lower temp on the evaporator, and that should acttualy make the defrost heater stay on longer not make it stop? am I correct?
26 May 2013 - 01:27 AM
I have ran the thermistor test (0-7) too and they all pass. should I trust this test response? the board and defrost thermostat is the only thing I replaced.
