gecustomer
Member Since 25 May 2013
Offline Last Active May 26 2013 04:46 PM
frost buildup in GE Arctica refrigerator
25 May 2013 - 10:24 PM
I had heavy frost build up in my GE PSS29NGNAWW freezer section. I have replaced the maun board and the defrost thermostat. I have measured the continuity for the good one and the bad one, they both measure almost zero ohm in room temperature  Is my old thermostat good or bad? I thought it should have continuity at cold temp and none when gets warmer? Am I correct? But my problem still exist, The evaporator coils inside the freezer back panel buildup frost? I can turn on the heather manually from diagnostic menu (1 - 4).
