Topy
Member Since 26 May 2013
Offline Last Active May 29 2013 04:54 PM
In Topic: Fisher Paykel E522BRFXDU2 Water dispenser not working.
29 May 2013 - 03:05 AM
Spot on !!
Problem fixed now.
I was planning to pull the fridge appart this week end. no need now thanks to you.
Fixed in 5 minutes.
Thank you again for your help.
27 May 2013 - 02:25 AM
I have tested the solenoid and it is ok. When appying 12v current it opens. Both solenoids (water and ice) are ok.
So far i know that when the dispenser button is pressed there is no current going to the water solenoid. Nothing accros the two tabs of the blue terminal.
I just need to locate where those wires go back to in the fridge.
Thanks for the help.
26 May 2013 - 03:32 AM
Yes it used to work fine. It started to "play up". The tap icon used to come up and no water. Then after a few hours water would come out again.
Now it doesnt work at all.
I cleared the lines and air was passing through.
Solenoid is ok.
Ice maker works.
Thank you for your help.
