Repairit2
Member Since 26 May 2013
Offline Last Active Today, 07:43 AM
In Topic: Electrolux Range M# EW30ES65GSE
27 February 2015 - 01:18 PM
I had to reschedule this job due to the weather... I arrived at the job and found the hot limiter contacts open, so I replaced the ESEC UIB which took care of the hot surface light flashing on the stove top when the surface was cold. Many thanks Mr. Samurai & Durham Appliance!
In Topic: ZFSB27DYBSS ice maker dispenser removal
26 February 2015 - 10:25 AM
These are a little tricky to remove, first you have to remove all the screws on the door behind the door gasket. Next, pull the inside part of the door off and then you will see a styrofoam cover in the area where the dispenser is located, carefully cut the tape going around this area, once you remove the styrofoam cover you will should see 6-8 screws holding the trim and dispenser assembly. You must be very carefull to replace any foam or foam sealant when doing this repair... if it is not sealed properly you will have a major condensation leak in the freezer.
25 February 2015 - 09:53 PM
Thank you both for very informative information on trouble-shooting this issue! I will be going on this call tomorrow... i.e. as long as the weather co-operates and I will definitely keep you updated!
In Topic: G.E. Profile Microwave JVM1870SKO3 Weirdness.
20 February 2015 - 02:07 PM
Is it the fan inside the microwave or for the cooktop exhaust fan?
