tgafford
Member Since 28 May 2013
Offline Last Active May 29 2014 07:14 AM
Maytag dryer power fail alarm
13 December 2013 - 04:26 PM
9 year old MDG7500AWW halts after hitting start, displays message 'power fail'. I found the electrolytic cap for the lower voltage DC supply somewhat bulged so I measured the AC and DC voltages. With 120v line the AC out of the transformer was 8.7 and the capacitor voltage was 8.1, should have been 10 or so. I replaced caps for both supplies, washer no longer senses power fail at motor start and works fine. $5 fix for $500 control board. 3300 uF at 16V and 1000 uF at 50V.
maytag front load washer won't spin
29 May 2013 - 11:04 AM
My mah7500 tries to spin but fails to go into high speed.  when I access the diagnostic screens and do an unloaded spin test, it shows an imbalance value of up to 200 or so at speeds up to 300 RPM, then zeroes out when it goes faster with no load.  It will spin to 1000 rpm smoothly.
It doesn't throw an imbalance code during the cycle - the only stored codes showing on the diagnostic screen are "7" - heater failure, which I'll deal with as a separate issue)
The only explanation of plaster detection I could find is in Maytag's patent number US6594841 (you can see it on Google's patent site) where it describes looking for erratic torque as it runs the drum slowly.  My drum isn't noisy, but I don't see what this could be other than bad bearings.  I haven't pulled the unit out to hand-rotate the drum and feel the bearing for myself.  what is my next step?
If it is bearings, I've read that the official fix is a new basket / drum, while there are some web sites that talk about replacing the bearings themselves.  recommendations?
