Scottdottcom
Member Since 30 May 2013
Offline Last Active Jul 30 2015 02:33 PM
Frigidare built Kenmore Refrigerator Condenser fan access 253.44723100
17 July 2015 - 03:03 PM
Does anybody have a tip for changing out the condenser fan motor on this under engineered appliance?
Does not look possible from the front and the condenser coil is blocking me from the rear attack.
Any ideas would be welcome.
253.44723100
Kitchen Aid Refrigerator KBRA20ELSS01 Bubble Trouble
25 June 2015 - 07:55 PM
Water dispenser continues to get air into the system causing long delays for the water to dispense.
Customer has had a filter bypass installed since day one.
When the water dispenser is not used for a length of time there is a lot of air that gets pushed through before any water is dispensed.
I don't see water leaking inside or out.
I suspect the filter head (Part number: 67001669
) may be faulty.
Anyone run across this scenario?
Kitchen Aid compressor and heat exchanger KSSS48DAX01
10 June 2013 - 04:41 PM
I have come across a Kitchen Aid refrigerator in need of a new compressor and heat exchanger. The OEM "horizontal" compressor has been changed out by another party some time ago and I am unable to find any information on the compressor. My local supply houses are only able to tell me that the items I am looking for are no longer available. Does anyone have some cross reference information for this model?
Kitchen Aid
Model KSSS48DAX01
Serial QC1200013
Thank you,
