BK1017
Member Since 03 Jun 2013
Offline Last Active Jun 04 2013 02:26 PM
In Topic: LG Fridge LFC22740ST Not Cooling
04 June 2013 - 08:33 AM
The main PCB is failing to start the compressor.  This is verified by the fact that you have to cycle power to get the compressor to run.  When you cycle power, it initiates a main PCB self-test, which includes starting the compressor.  Beyond the self test, it's not starting the compressor.   Go ahead and replace the main PCB:  http://www.repaircli...mber=LFC22740ST
Main-Control-Board-EBR36222901-00787886.
Got it. Thanks. Replacing the board seems like a basic plug and play job. Any concerns when doing this?
Since the tech's visit, the fridge has continued to operate like normal. He must have a magic touch.
BK
03 June 2013 - 05:12 PM
I am having a similar issue on a lg made kenmore.. ... one thing to check is your pcb cover. If it is plastic, there is a possibility of interference with the board. see
http://appliantology...ittent-problem/
The cover was on back order and I will know if it fixes the problem soon
Thanks, but mine has a metal cover.
Have there been any fault codes displayed, er ff or anything else?
I have not seen any fault codes.
BK
