blairville
Member Since 07 Jun 2013
Offline Last Active Jun 14 2013 05:20 PM
In Topic: Older Lennox airhandler, replaced blower motor but it keeps shutting off
13 June 2013 - 07:49 PM
Well, went to Grainger, got the part. Everything is working fine. Probably needs freon, though. Does not seem to be blowing that cold. What is freon going for these days? It is the R22 type. Wished it was the newer one. It is a Trane, installed in 2007.
In Topic: LG LFX25960st er ff error
13 June 2013 - 06:11 PM
I got the service manual from this site, Thanks so much, and did the test mode. Link to download service manual, if anybody felt froggy. http://appliantology...service-manual/
There are four steps, first starts it, second closes the damper, third shuts off compressor, closes damper and force starts the defrost. Steps one and two went off without a hitch. Third, the compressor and damper closed like it was supposed to, don't know if the heater was working, still trying to see where to check that at, but the display was supposed to show 33 33, but it did not. It showed the regular display. pushed button again, it made the display go like it was supposed to in step no. 1. and compressor stayed off like it was supposed to, there is a seven minute delay.
Does that further confirm that the board is bad?
13 June 2013 - 02:11 PM
AO Smith DL1056
  • HP: 1/2
  • V: 115
  • Amps: 6.5
http://www.emotorpro...rpm-dl1056.aspx
When I ordered the part, the home depot AO Smith part, it said it was the 208-230v, which is obviously incorrect, according to your link above and other ones on the net. That is the first thing I checked. Well there you go. Hopefully after taking this one back and getting the correct one, I will make sure it is the correct voltage, I will get the new part from Grainger, my A/C will work correctly and not shut down. Thanks all, I will update when exchanged.
13 June 2013 - 01:34 PM
What voltage does the air handler operate on? 120? 240?
What voltage is the old motor?
What voltage is the new motor?
Microfarad )mfd) on the capacitors?
What volt rating for motor capacitors? 370....440?
Correct blower wheel rotation?
What is fan voltage OUT of the relay board?
It is 240
Voltage for both is the 208-230
10 MFD 370
yes, correct blower wheel rotation because when it was on, it was blowing real hard in the house.
The last question, are you asking about the voltage out of the blower relay?
sounds like
the "old" Motor was 220v
and "new" Motor is 120v  :whistling:
old Motor part number ?
new Motor part number ?
Both motors are 208-230.
Old part Emerson K55HXTGB-8797
New part AO Smith DL1056
Like I said before, they were exactly the same except for amperage.
Should I return the home depot part and get the correct amped one? There is a Grainger store nearby, they have one there.
Thanks again for your advice. I don't know when the last motor was "fried". The last owner bought the property in 2010 and moved out april 2012, so this house has been empty since then.
12 June 2013 - 10:17 PM
Fan motor is working when first turning on and works for several hours afterwards. Then it shuts off, then the error. The motor is turning freely. So I think it is a bad control board. Is that the same as the controller? Thanks for the help by the way.
