Gnominator77
Member Since 09 Jun 2013
Offline Last Active Jul 12 2015 07:38 PM
In Topic: Samsung Fridge RF265ABRS/XAC
20 June 2015 - 08:47 PM
I didn't check the door switches, but I have verified the complaint. I heard it as I walked into the home... beeping. Then I opened the fridge door and saw the fridge temperature display going up and down with the beeping. It is like someone is setting the temp. when no one is. There is no complaint of cooling issues, or ice maker issues, just the annoyance of the beeping with doors open or closed.
In Topic: Kenmore Dryer C110-8030091 - Need element. Part number 337365 NLA.
08 June 2015 - 06:40 PM
RPL WG04F04623 NLA:ELEMENT ASSY
Subbed from part# 337365 WHEN SOLD OUT, THIS PART IS NLA. MAKE SURE THERE IS STOCK IN THE BRANCH YOU ARE INVOICING IN.
Rush this item   1    favorite.gif Go to result
This is what I am getting when putting that number into Reliable Canada. Not sure why its subbing to a new GE number though. The one in stock is main warehouse in Ontario.
In Topic: Ge Profile PFS22SISBSS Refrigerator/Freezer
08 April 2015 - 03:04 PM
This is the part for your model if you should happen to need it. A simple voltage check will lead you in the right direction.
Part number: AP4300623
08 April 2015 - 03:00 PM
Let us start at the beginning. Why did you change the board to begin with? What symptoms were you having? A lot of times when I change a GE board for the condenser fan motor not running I change the relay/overload as well. With the fan not running the relay is going to take a beating with all the heat not being dissipated.
In Topic: Defrost Thermostat on Whirlpool EB9FVHXWQ01
01 April 2015 - 04:48 PM
Listen to Brother Durham and order yourself a new jazz board.
