Gnominator77
Member Since 09 Jun 2013
Offline Last Active Today, 09:16 AM
#308756 Whirlpool Cabrio WTW8240YWO leaking from dispensers
Posted by Gnominator77 on 03 December 2014 - 07:52 AM
There was a bulletin Whirlpool put out for this problem. The dispenser has been changed to add an additional drain port.
#308686 Won't reach Pre Heat Temp 790.96512406
Posted by Gnominator77 on 02 December 2014 - 01:37 PM
Usually I very carefully can peel the old overlay off.. use very little heat from a heat gun. If you "peel" some of the white off I have successfully used a little white out or white touch up paint to cover the exposed areas. If you need a new overlay here it is... but its an expensive sucker... Good Luck!
Part number: ap3767970
#303966 Whirlpool Gold GD25DIXHS02 - defrost heater 2323198
Posted by Gnominator77 on 23 September 2014 - 05:53 PM
No, it shouldn't have any continuity from the terminals to the outer casing. If you are getting any reading at all from either one of the terminals to the casing, its shorted. Just like an element in an oven or on a stovetop. Make sure you are isolating the heater from the circuit when testing.
#303269 GE dishwasher gsd5560g00ss repair help WD26X10013
Posted by Gnominator77 on 13 September 2014 - 07:52 PM
That part in the picture is the turbidity sensor... and should go back where it was on the old pump and motor without removing the wires. The third picture you posted is wiring harnesses that come with the new pump and motor to convert to any configuration.
#302067 Kitchen Aid KGRA806PSS00 Oven works fine at times then at other times it heat...
Posted by Gnominator77 on 28 August 2014 - 08:03 PM
It's not uncommon for sensors and thermistors to test within range, but fail under load.
#301093 Whirlpool stacked washer/dryer LTE5243DQ8. Heating element won't shut dow...
Posted by Gnominator77 on 15 August 2014 - 07:17 PM
Did you check if the heating element is shorting to ground?
Part number: ap3094256
#300686 MAYTAG REF/FREZR.Model MFI2568AEB
Posted by Gnominator77 on 10 August 2014 - 07:45 AM
It appears that there are two different boards for these series of fridges. The MFI2568AEB calls for board 12920710 and the 12 and 13 series of fridges call for board W10310240.
Part number: ap4014490
Part number: ap4568436
#299999 Freezer control slider not working,10672206201
Posted by Gnominator77 on 30 July 2014 - 07:28 PM
I've seen a lot of times when the fan motor stops the airway gets a lot of ice and frost in it. Make sure where the fan cover sits into is clear.
#299697 Maytag Neptune MDE5500AYW Moisture Sensor
Posted by Gnominator77 on 27 July 2014 - 05:11 PM
In reality they are just two pieces of metal that are incased in a plastic housing. One end of the metal is formed so a wire can push on and the other is just bent over in the manufacturing process. You had it right all along.
#299605 Maytag Neptune MDE5500AYW Moisture Sensor
Posted by Gnominator77 on 26 July 2014 - 09:08 AM
They both go onto the terminals on the bottom... they both go up to the control.
Here is the wiring info... the wires should be marked.
#298848 Frigidaire refrig FPHI1887KF1 weird thing on defrost timer
Posted by Gnominator77 on 16 July 2014 - 10:13 PM
It has a self adhesive backing on it and it sticks to the housing under the timer. It's been awhile since I installed one, but it's pretty straight forward and comes with instructions.
#298832 Frigidaire refrig FPHI1887KF1 weird thing on defrost timer
Posted by Gnominator77 on 16 July 2014 - 07:31 PM
Part number: 5303918301
#297894 Whirlpool Gas Dryer GGW9868KQ0 (Senseon) - Intermittent Gas Ignition Failure
Posted by Gnominator77 on 04 July 2014 - 07:14 PM
I would be leaning towards the gas coils. They sometimes will work fine when the dryer first starts but fail later on in the cycle.
Part number: ap3094251
#294029 KitchenAid Dishwasher KUDS011JWH0 - Thermal Fuse Blown
Posted by Gnominator77 on 19 May 2014 - 09:09 AM
Also have a look at the door switch connections for corrosion.
#293930 Samsung Refrigerator RB1944SL/XAA Not Running
Posted by Gnominator77 on 17 May 2014 - 02:17 PM
Great post Durham! Love the molten lava and dry ice reference... ha! Gotta have a sense of humour in this profession... if not, its a lonely existence. :)
