marwoods
Member Since 17 Jun 2013
Offline Last Active Jun 23 2013 07:12 AM
#258778 Kenmore FL 417.44072300
Posted by marwoods on 21 June 2013 - 01:17 PM
Thanks for all the advice. Washer is working as it should after shocks were replaced.  In order to replace the shocks, we had to remove the motor control board for access and if there had been a loose connection somewhere, we presume it was taken care of when the motor control board was re-installed.
In the end, it seems the broken shock was the culprit causing the F04 error.
