BenR
Member Since 18 Jun 2013
Offline Last Active Nov 12 2014 10:46 AM
#259281 LG WM1814CW stops shortly after cycle start
Posted by BenR on 27 June 2013 - 01:14 PM
I ordered the Ball Sensor and the main PCB. Just replacing the Ball Sensor was not the answer. I tried running a load and in two minutes or so the washer stopped just like before. Installed the new PCB and the washer is running fine now. Might not have needed the Ball Sensor at this point but wasn't worth pulling the machine back out again to remove it. Life is good, clothes are clean. Thanks to ALL!
