Koald
Member Since 18 Jun 2013
Offline Last Active Jun 22 2013 02:43 PM
Maytag Performa PAV2300AWW thrust bearing assembly order
19 June 2013 - 11:05 PM
Hi!  In the process of replacing the snubber, I jumbled-up the thrust bearing washers and don't know in what order to replace them.
Unless I have lost something, I have one large washer which I believe was at the top (nearest the brake assy.), with three very similar, smaller washers (two thin & one thick), a radial roller bearing, and a wavy spring washer.  I've looked at the diagams, but can't be sure of the order.
I've looked through the forum, but no luck so far.  Any suggestions?
