justyn
Member Since 23 Jun 2013
Offline Last Active Jul 07 2013 05:35 PM
In Topic: Display dead? Kenmore Elite Top-Load Washer
03 July 2013 - 02:39 AM
Just spent an hour replacing the touchpad and the display is still blank. Still getting 120v per earlier tests. Did I just waste $200?
28 June 2013 - 12:24 PM
Thank you.  I've ordered the new touchpad.  Is there a tech sheet that provides steps for replacement?  Any advice?
27 June 2013 - 03:21 PM
Ok - the instructions are unclear to me.  In the doc, the troubleshooting guide on Page 9 indicates I should conduct Test #1 on Page 11 and Test #4 on Page 13.  I've walked through both tests.
Test #1 indicates that I should replace the machine control board.
Test #4 indicates I should replace the console panel/touchpad assembly.
Do I need to replace both components?  Isn't it possible one is broken but not the other?
Thanks.
26 June 2013 - 02:40 PM
try it again, works for me
Tried again - it works in IE but not Firefox.  Thanks.
25 June 2013 - 08:33 PM
I also measured the DC voltage between P11-4 on the control board and the following pins on the ribbon. All were between 0.9V and 1V
P11-10
P11-11
P11-12
P11-13
P11-14
P12-2
P12-3
