brianl0646
Member Since 12 Nov 2006
Offline Last Active Aug 18 2015 10:49 AM
In Topic: Danby Wine Fridge DWC440BL not cooling
18 August 2015 - 01:33 AM
It's a samsung compressor. Did a search online and I see the same problem with samsung refrigerators using the same relay. The number on the relay is L4-jahwa. I found a post refrenceing a MARS 32330 as a replacement for it with the same symptoms, hot compressor wont't start. I ordered one online for $10 with shipping. I'll see if that fixes it.
In Topic: Kitchenaid kudi02frss1 door spring broken (I assume)
15 March 2015 - 09:24 PM
I just found a video at appliance parts pros. Looks easy, I'll buy the part.
In Topic: GE Dryer dcvh680gjtmr won't dry
12 August 2014 - 01:15 PM
Thank you, I was posting this for a friend of mine who told me the dryer wouldn't work. (hence the bad model number), I have not seen the dryer, but it looks like the problem is they don't have a gas connection at their new place and didn't realize it was a gas dryer.
Brian
In Topic: Kenmore washer 110.20022011 won't fill
27 October 2013 - 10:38 PM
The water is connected, the water supply is working both hot and cold. There are no plugs in the filter screens on hoses or washer, drain hose is connected properly. The lid switch seems to be working because it locks. It makes noises like it wants to fill but has no water. I was not able to access that document referred to above to see what the valve problem or main control problem is so I am stuck at the moment. I thought theses top loaders were simple compared to the front loader ones, I guess not.
Brian
In Topic: Replacing ignitor on GE profile range jgb920sec4ss
04 March 2013 - 11:22 PM
I figured it out, thanks.
Brian
