brianl0646
Member Since 12 Nov 2006
Offline Last Active Mar 16 2015 12:53 PM
Kitchenaid kudi02frss1 door spring broken (I assume)
15 March 2015 - 09:17 PM
I opened my dishwasher today and the door just fell open. There was nothing slowing its descent. So I am assuming there is a spring that is broken. Is this an easy fix?
GE Dryer dcvh680gjtmr won't dry
12 August 2014 - 01:57 AM
It spins but there is no heat and will not dry. Lint filter is not clogged and vent is clear. What should I start with to troublehoot? Could it potentially be something simple?
Brian
Kenmore washer 110.20022011 won't fill
27 October 2013 - 05:51 PM
I have a Kenmore top loading washer in a house I just purchased. Looks like it never has been used but it won't fill. I push the start button, tried cold, warm and hot and all I get are clicks and nothing happens. I took off the hoses, verified water comes out. Checked the screens on the washer inlets to make sure they are not clogged. I can't think of anything else that I have missed. Any help or ideas would be appreciated.
Brian
Question about inner bake element in GE Monogram pro range ZDP30N4HSS
12 July 2013 - 05:25 PM
There are 2 bake elements in the oven on this range. I turn it on and the outer element gets red quick and the inner element gets hot instantly (I have burns to prove it) but does not turn red. Do these serve different purposes? And maybe run depending on temperature that is set? This was called out as defective on a home inspection but I tend to believe since they are 2 separate elements they are designed to do 2 different things. I would appreciate any help here.
Thanks much,
Brian
Replacing ignitor on GE profile range jgb920sec4ss
04 March 2013 - 10:40 PM
I have the new ignitor, I have removed the bottom of the oven and can see the ignitor on the burner tube, but the wires just go into the bottom of the range. I turned it around, but can see no way to access the connection. Do I just cut them off and splice on the new one? I don't want to do that if there is a better way. Any help will be appreciated. Here is a picture of what I am dealing with.
Brian
Attached File  ignitor.JPG   127.29KB   18 downloads
