BigD72
Member Since 28 Jun 2013
Offline Last Active Jul 10 2015 12:38 PM
In Topic: GE GSH25JSTASS fridge help
10 July 2015 - 12:39 PM
Thanks for the responses. I just got the main control board in and installed. It was the issue. Up and running now.
In Topic: Whirlpool Duet front load washer tub is cocked or sagging
01 July 2013 - 07:50 PM
i called whirlpool today and they will send out someone and said the basket and tub both can be replaced under warranty if that is what the AE factory service guy deems the problem is. Thanks everyone for your advice and responses. Spannerwrench, your are correct I will have to pay the service call which will still be cheaper than a new unit.
30 June 2013 - 09:48 AM
We only used HE and not much of it. We did however used the liduid HE for up until last year and swapped over to the powder. We had heard the powder would reduce the "moldy" smell. One other thing, I am going to call whirlpool monday and Lowes as well. i had a 4 yr extended warranty with them that expired on 6-13-2013 and the washer broke on 6-24-13. I called the 24 hr line for warrant service and they are going to have a manager from the warranty dept. call me monday. I am going to see if they will do anything since the spider arm corrosion occurred well before 6-24 when the arm finally give out.
30 June 2013 - 09:17 AM
Thanks, I subscribed. I am just very hesitant to go back with a front loader. When i first begin trying to find my issue searching the Internet, the bearings going out and or the spider arm corroding and breaking looks like a huge issue. Is this precisely with the Whirlpool designs or is this what comes with all front loaders? I just don't want to be buying or replacing the tub every 5 yrs.
29 June 2013 - 10:54 AM
If I can't get them to cover this and have to start looking for a new one do you have any suggestions? Are there certain ones you wouldn't buy because you see them all the time for repairs. Or would you not even suggest a front loader. Thanks for all your info and help thus far spannerwrench
