Steveandedie
Member Since 02 Jul 2013
Offline Last Active Jul 11 2013 07:31 AM
In Topic: Frigidaire front loader won't agitate or spin
09 July 2013 - 12:10 PM
OKey Dokey,
we will order up the shocks and speed control board.
btw, we followed the instructions in that U tube video at the start of the repair, and the door switch and motor checked out OK.
THX - we'll let you know how it works out.
S&J
09 July 2013 - 07:03 AM
Hi,
By the way, the door remained locked even though it wasn't agitating or spinning.
We'll need two shock absorbers, but what other parts do you think we need to replace?
We are no longer with the machine, but maybe a neighbor can run some tests if needed.
S&J
03 July 2013 - 03:06 PM
Hi There,
all plugs were found to be on tight when we started.
the tech sheet part # is 131941100 0005
the wiring diagram P/N is 134014800
we put all parts and connectors back on and ran your test.
we put the timer dial on final spin and were surprised to find that the machine did rotate and then spin.
the door is really locked during this spin cycle.
we unplugged it from the wall, and the door remained really locked for 60 seconds.
we plugged it back in and the machine picked up where it left off and finished the final spin cycle to the end, all the while spinning normally. (Yay! we thought)
then we set it to a full wash cycle.
it did agitate, but when it got to the first rinse, it did not spin.
we let it run through the rest of the regular cycle, and it failed to ever agitate or spin again, including the final spin.
We know tomorrow is a holiday....what's your schedule?
THx so far!
