Bingbing
Member Since 04 Jul 2013
Offline Last Active Jan 16 2015 01:48 PM
In Topic: LG REFRIGERATOR LFX25976ST/00 DOOR MULLION WIRING
30 December 2014 - 10:44 AM
Thanks!
I remember having some condensation in between the doors this past summer. This refrigerator has been performing well otherwise.
Looks like I'll be ordering a new mullion after coffee.
Cheers-
In Topic: Bosch Dual Fuel HDI7282U/07 Range
20 July 2014 - 11:52 AM
Okay I got it off. There are two accessible torx screws on each side total four plus four below. Did not have to remove the main top.
20 July 2014 - 11:00 AM
Thanks I've never removed a maintop before. Is there any way to post/share  your diagram of the screws and components holding the maintop and the front panel screws? Also any idea how heavy the maintop is?
In Topic: Bosch Range HDI7282U/07
24 November 2013 - 08:24 PM
Thanks very much ! I'll give it a shot.
24 November 2013 - 12:48 PM
Thanks fo the reply. The gas portion of the valve is functioning. However, the electrical switch is only providing a burner spark about 10% of the time.
The other three burner switches work fine. It seems the switch might have gotten wet. I understande I would need to replace the harness. I was seeking clarification on removing the front panel and replacing the harness.
If there is an option to replace just the switch please let me know.
Regards
