dpwct
Member Since 06 Jul 2013
Offline Last Active Jul 15 2013 08:23 PM
In Topic: Bosch Dishwasher spray arms are not turning
15 July 2013 - 12:12 PM
Found the problem,  a plastic cap was lodged in the recirculator intake( right side under filter )?  under the filter, it as restricting water flow
all is good now
08 July 2013 - 03:38 PM
Also is there a way to run a diagnostics on this model
08 July 2013 - 09:38 AM
Thanks is there a photo anywhere to show  where to find/access the impeller from inside the tub
While turning the impeller from inside tub have someone else watch the fan blades on the motor with a mirror under the machine.
Most likely you will find when turning the impeller the motor isn't actually turning, thus when motor is running, impeller isn't turning or is only turning very slowly from friction with back portion of impeller which front vane section has broken away from.
07 July 2013 - 11:09 PM
How can I be sure that is the problem, and if so how long do you think it would take me to replace the part (first time I am doing this)
