ronovabch
Member Since 07 Jul 2013
Offline Last Active Dec 18 2013 09:20 PM
In Topic: Kenmore (whirlpool) D/W 665.13744K603 Control Panel or Control Board?
07 July 2013 - 12:34 PM
Yep thanks !
Board looked ok..
.The tech sheet says to confirm if keypad is no good... disconnect the keypad and reassemble console and power up,  if the board does not see a short or issue ,  the drain pump will turn on... which it did
thanks!
When all else fails read the directions I guess..
thanks again
Rono
