pastorjoelcm
Member Since 10 Jul 2013
Offline Last Active Jul 17 2013 08:09 AM
In Topic: Kenmore tumble washer 41747102700 bearing problem
17 July 2013 - 08:10 AM
Thanks for the advice.  I guess you can't win them all.  The upside is that I now know how to take apart a front loader and get to the different parts.
16 July 2013 - 01:58 PM
I actually looked at the machine today.  No leaks.  Noises were a thump and squeal as you turn.  I completely took apart the machine even taking apart the front and back of the tub.  I hit a stand still when trying to separate the back from the basket.  I tried a wood block and a rubber mallet and the thing did not budge at all.  I ended up wailing on it as hard as I could and got it to move some but I cannot get the shaft through so I can examine the spider to see if it is bad or not.  I was able to notice an obvious wobble as I turned it and etches in the tub where the screws are hitting the tub wall.  I'm pretty sure its' the spider but not 100% til I can see it.  I would hate to toss it after all that work if it is just the bearings.  Any tips on getting the last part of the shaft through.  I had to hit it so hard that I believe the edges of the shaft have miss-shapen some.  Thanks
In Topic: mvwx600xw0 won't drain
13 July 2013 - 03:32 PM
Update:  Just replaced the mode shifter.  It was a piece of cake & my washing machine is fixed.  My wife is very happy! Thanks so much for the expert advice!
11 July 2013 - 10:36 AM
Thanks, I'm ordering the part and am going to give a try.  I'll let you know how it turns out.  By the way, I love this website & forum.  Great information & help for a reasonable fee.
10 July 2013 - 08:59 PM
When it fails, the clothes are sopping wet and cover the bottom of the tub.  When it works, you can see the bottom of the tub and clothes make a ring showing that it spun and they are wrung out correctly.
