laramy
Member Since 12 Jul 2013
Offline Last Active Jul 21 2013 07:04 AM
In Topic: GE Front Load Washer (fills and drains)
20 July 2013 - 11:00 AM
Tip: Even though the Inverter tested good according to every ones white papers, when testing for the 6 ohms on the board and reads as such, the Inverter was still bad, I inspected the Bad one a little further and found an onboard Fuse on the circuit board that looks like it can be replaced without any soldering. I haven't tried to do it cause, well I'm up and running now, but maybe the next person can give it a shot and $ave some bucs.
Good Luck!
20 July 2013 - 10:39 AM
We'd love to hear how to turns out so please let us know!
Ok, although there wasn't much left to replace on this thing given the problem, the award goes to PDuff,, pretty much sum's it up, it was the Inverter after all.  Beer on Me! Oh well the way I look at this is that this machine is pretty much rebuilt for the high dollar stuff, besides the Pump, Pressure switch, Door Lock, H/C fill Solenoids and maybe some odds and ends, hoses and what not, but all that seemed to be ok, so away I go, on to my next task on my Honey Do list, whatever that may be. Thanks to all! Great Forum! :cheers:
Larry
13 July 2013 - 11:29 AM
Motor inverter board, new, OEM part with one year return policy: http://www.repaircli...mber=WHDVH626FW
Thank you for the assistance and info, if this doesn't work "I'll Be Back!"
13 July 2013 - 11:10 AM
Sounds like new inverter time, Brother Larry.  Double check all wire connectors at the inverter.  Does unit agitate after fill?
Will do! Thanks for the feedback, where's my Check Book? UGH!
12 July 2013 - 03:20 PM
No agitation at all, motor stands still
