mikal
Member Since 14 Jul 2013
Offline Last Active Jul 15 2013 12:13 PM
In Topic: Wolf R364G Burner/Griddle Ignitors
14 July 2013 - 07:34 PM
OK.  I'll have to go through all the connections carefully and see if the behavior changes.  Thanks!
14 July 2013 - 07:06 PM
Huh, maybe I was wrong about the individual ignitors firing before.  Lets face it, wife's not here and I only have a distant relationship with the range.
So I did the "jiggle the connections, knock the box about a bit" type of thing and sure enough, all the ignitors for the top burners are now firing together.
Makes perfect sense given the move and all.  And it's that module that you first listed - RI 306.  I'll check with the wife about the individual versus all ignitors firing thing, but I'm certainly happier with this than the left-rear/front-right thing.
Thanks!
14 July 2013 - 06:41 PM
OK, I do have and exploded parts list for the range, found the module on the diagram, looks like I should be able to get to it without too much trouble.  So I'll open her up and see what I see.  :blinky: Thanks again.
14 July 2013 - 06:35 PM
Thanks GMF.  Yes, they were previously firing independently.  If you have anymore detail on exactly how I should "check the Range Spark Igniter Module" that would be appreciated.  But regardless, thanks again, you did give me some direction and I appreciate it.
Thanks!
