wapitiscat88
Member Since 15 Jul 2013
Offline Last Active Jan 05 2015 10:59 AM
Samsung RF263 defrost sensor reposition
15 July 2013 - 09:48 AM
Well, the evaporator is iced up again. I'm beginning to think that the drain may be clogging with ice and have read about repositioning the sensor to a different location on the evaporator. In one post the "last run on the suction side" was referenced for a different model. Can someone describe a similar location for the sensor on this model? Also, what are the tests to do at the evap assembly level with respect to the heater and sensor? Do I test these with power on? Do I test these while the unit is in forced defrost? Thanks.
Todd
