educatedguess417
Member Since 16 Jul 2013
Offline Last Active Jan 21 2015 10:37 AM
#311305 Maytag Dishwasher: No Water
Posted by educatedguess417 on 16 January 2015 - 05:50 PM
What is the voltage at the water valve during the fill cycle???........Water 'on' at the valve under the sink????
Sensei, thanks.  Yes, the water valve is on, I made sure of that.  I bought a multimeter and will be checking the voltage next.  I need a break but will report back to you later.
I suppose I should also remove the supply line hose and check for the simplest of all problems -- that water can still flow through the hose.
Thank you for responding so quickly.  My wife is napping in that part of the house so I will check the voltage later and post it here.
Thank You!
