Harpman59
Member Since 18 Jul 2013
Offline Last Active Jul 23 2013 05:12 PM
In Topic: Frigidaire dryer stopped mid cycle and now won't run...
23 July 2013 - 05:14 PM
Just wanted to drop a post by y'all and thank you for your help. I soldered in the new start relay, repaired the wiring, put everything back together and "voila" I'm back in business!
19 July 2013 - 04:14 PM
Remember when I said "...but I think it may be a little beyond my capability!   :kopkrab:..."
Never mind, I shouldn't ever underestimate my talents lol!! I took another look at the relay and there's only 4 pins so, while I'm not an expert here, I do  have some tools and a little mechanical inclination.
Solder iron fired up and relay removed...
photobucket-6605-1374267122443_zpsa838f7
A quick search for "Potter and Brumfield part# T9AS1D22-12" pulled up several results of the part, ordered thru Newark
http://www.newark.co...537483461|plid|
and the shipping was 3.78 times the cost of the (damn) part...which was....... $3.78.....I thought that was ironic.
Anyway, I'll post results when I solder the relay in and stuff all the parts back into what was my dryer...
KC
19 July 2013 - 10:44 AM
Thanks heaps for the speedy responses! I've taken the circuit board out of it's housing and I'll consider that but I think it may be a little beyond my capability!  :kopkrab:
So, you think the cause was just poor contact at that terminal? Also, I've found a re-manuf. panel, would you trust that? It'll save me about 40 bucks from the least expensive new one I've found.
19 July 2013 - 09:43 AM
Thanks! This is what I'm thinking but should I try cleaning these contacts? Maybe a little dielectric grease on there? Or should I even try, considering the fire hazard? I have 14ga wire and can replace the burnt wire myself unless you see an issue with that as well.
19 July 2013 - 08:56 AM
photobucket-8821-1374241960034_zpsede3ec
