johntech
Member Since 22 Jul 2013
Offline Last Active Yesterday, 01:32 PM
In Topic: Kenmore 106.57579790 S x S ice/water dispenser cover plate removal
25 July 2015 - 05:02 PM
Same way as all the others. I tape my putty knife so I don't scratch anything. I believe that one comes apart like the inside trim on a microwave door, It always pops off before it breaks for me knock on wood.
In Topic: Ge washer wbvh5300k0ww leaking at dispenser
24 July 2015 - 09:22 PM
This one is actually leaking out the dispenser drawer and runs down the front of the machine.. I made it work properly by adjusting water pressure with the supply valve and convinced myself to order a valve. Then the more I thought about it I lost confidence that a valve will fix it.
In Topic: GE J TP70S P2SS oven
21 July 2015 - 06:52 AM
Most of the time it is the touchpad when buttons do not work. If you already replaced the main board and your sure the buttons are not locked and you checked all wires and connections then next step would be to replace the touchpad.
In Topic: Apps?
19 July 2015 - 07:56 AM
Blue book is great for priceing, we use field harmony for scheduling but I would not reccomend it to anyone it is real clinchy at this time.
In Topic: Frigidaire Freezer FFFH21F6QW, how to put it in Celcius?
18 July 2015 - 06:44 AM
I've tried plugging that number into the frigidaire site and it said ther are no matches. If the number is right I would call frigidaire.
Sorry my eyes are not so good it
