SteveT
Member Since 26 Jul 2013
Offline Last Active Aug 15 2013 08:09 PM
Frigidaire washer LTF2940FE1 front load
26 July 2013 - 04:24 PM
I cleaned out the filter in the black hose/assembly between the outlet of the washer drum and the pump. Earned myself 3 quarters and cleaned out a little lint. It really wasn't bad. The washer goes for a while but at some point it just stops. Usually near the final 10 minutes or so. On rare occasions I can get the spin/drain only mode to start and water does come out of the house but stops before it is all out. The drum seems to spin and the belt for the latter seems to be fine. When this happens I can not get the door to open even if I press Pause/cancel. I have to unplug the machine and at some point I am able to open the door. Water is coming thru the hose. What should I check next?
