Riezinger
Member Since 30 Jul 2013
Offline Last Active Aug 08 2013 11:00 PM
In Topic: LG WM2487H has no power
06 August 2013 - 09:58 PM
Just a quick update, I rolled the dice on a new pcb and that fixed it! Big thank you Mr Samurai!
31 July 2013 - 06:15 PM
So it appears the led is out, had to unplug everything to find it, but hooked all back up and it's clearly not on. So this is a tell tell sign then?
31 July 2013 - 10:27 AM
WM2487HRMA
30 July 2013 - 10:12 PM
The top pin is either red or brown, the middle pin is green w/ yellow stripe, the bottom pin is blue. It get 120v between the top and bottom pins, so I would assume that is pin 1 & 3
