Luckydog
Member Since 05 Aug 2013
Offline Last Active Oct 23 2013 05:59 PM
In Topic: GE Washer won't drain with a full load
17 August 2013 - 08:02 AM
The pump makes a beautiful wooshing sound as it pumps super large loads of wash!  Thank you Grand Master, you have saved us!  The most fun I've had doing a load of laundry in so long.  I stood there listening to the glorious sounds of everything functioning and just feeling like the champion of the world.  Hee.
07 August 2013 - 07:48 AM
Thank you, I have ordered a pump and we'll see if that fixes the problem.
05 August 2013 - 07:20 PM
We removed and checked both hoses.  The debris from the pump was mostly sand, but there were some larger chunks of dirt-type stuff too.  The model is whdsr209d6ww GE washer.  Funny thing today, we ran a load on medium load size and it worked.  Now, I keep asking myself, "why won't it work properly on a large load?"  It does everything fine except the draining part.  It will even spin a large load, but only after the water has been manually drained.  Could this be a timer control issue?  It has gotten progressively louder over time.
