Luckydog
Member Since 05 Aug 2013
Offline Last Active Oct 23 2013 05:59 PM
GE Washer won't drain with a full load
05 August 2013 - 07:47 AM
We've determined that the pump will drain a small (test) load, thought we had the problem fixed--cleaned out a bunch of debris from the pump-- then put in a full load, and of course it no longer pumped the water out.  Why would the pump drain the water on a small load and not on a full load?  The lid switch seems to be working, at least enough to stop the agitator when we open the lid.  Once the water is drained, the washer will spin.  Any thoughts?  Are we barking up the wrong tree thinking that the pump is dying?  We're not very electrical in nature- better with mechanical stuff.  We do have a multimeter but I honestly don't understand how to use it.
