SnorkleZ
Member Since 15 Aug 2013
Offline Last Active Aug 22 2013 09:45 AM
Kenmore Dishwasher 665-16765691 Leaks Under Door
19 August 2013 - 04:51 PM
This Kenmore 665-16765691 Ultra Wash dishwasher leaks erratically.  At first small leaks, but much more today.  Loading doesn't matter - leaks even when run empty (I've included a photo of the water level during a leak).
I've replaced the door seal (thought for sure that would fix it!).  No change.  I was suspecting the float switch of making it over fill, but as I saw today the water fills up to touch the bottom of the heater element, which I think is the right height.  This dishwasher has worked perfectly for a decade, so the installation and leveling should be ok.
I guess the next step is to take off the door and see if anything looks wrong at the bottom?
Any suggestions would be appreciated.
Attached File  IMG_0381.jpg   96.56KB   0 downloads Hmm. This seems to make my posted image a small thumbnail :-(
