markmac3
Member Since 17 Aug 2013
Offline Last Active Sep 06 2013 05:22 PM
In Topic: LG LFC25776SW/00 thermistor value chart
18 August 2013 - 09:15 AM
new details. measured freezer and fridge temps this morning, 39f on fridge 22f on freezer. compresor has ran constantly all morning. measured amps on compressor and was getting 1.8 amps, label inside doors. all fans are running. i pushed test button amps stayed same. pushed test button again an 22 was displayed on temp leds. is this a code? about to look at evap coil again.
17 August 2013 - 12:54 PM
which board controls defrost cycle, board mounted at bottom near compressor or main board?
17 August 2013 - 12:16 PM
i am unable to post pic. the freezer got down to 37 F. the lines coming from compressor were icing up. on schematic on back of refrigerator i took voltage reading on defrost heater and was getting 120v. looks like heater is stuck on.
17 August 2013 - 10:01 AM
defrost sensor reading 13.4k
17 August 2013 - 09:53 AM
it has done thawed out. it was more like flakeyice build up if that helps. is tthis normal?
