Ke5wxn
Member Since 17 Aug 2013
Offline Last Active Sep 13 2013 02:05 AM
795.75543401 Door harness
21 August 2013 - 09:55 PM
Bought this unit used knowing the display was bad. Replaced display board and main board and found the display was still non functional. Ohmed out the harness and found the black wire from the connector at the door hinge to the display conector had no continuity. Gently pulled up on the harness and black wire broke about two inches inside the door. How in the world does one get the harness out to repair or replace? Thank you, Matthew.
