aaronDIY
Member Since 21 Aug 2013
Offline Last Active Aug 23 2013 09:30 AM
In Topic: Blue Star Range Thermal Valve Not Working
22 August 2013 - 11:20 PM
thanks dexter,
Yea those videos are cool, very informative. I tested my valve and I dont have continuity. So now being as my range is out of warranty its costing me two thermal valves at 125 bucks a piece and some wire. I was looking to see if the Repair Clinic has Blue Star replacement parts, but no luck either.
Would you know if the wire used in ovens is rated for hot appliances or can I get the wire at my local Homedepot?
22 August 2013 - 10:57 PM
I found the short. Looks like the orange and white wire with a black insulating sleeve that connects to the igniter with the thermal valve got smashed somehow. I dont see any damage on the side of the oven, so I dont know how it happened.
22 August 2013 - 03:55 PM
Hey Reg,
No, I've been looking for one though. Seems kinda hard to find any info for Blue Star ranges.
22 August 2013 - 11:53 AM
I switched the broiler igniter to the oven and still nothing. I also tested the continuity from the orange wire that connects to the thermal valve to the oven frame and it shows that there is a short some where. So Im not convinced its the igniter.
21 August 2013 - 03:59 PM
Thanks for the reply Kohai,
It seems that the thermal valve has shorted out. Would a bad igniter do that? or if I put in a good igniter, will that make the valve work again?
