olyteddy
Member Since 23 Aug 2013
Offline Last Active Yesterday, 09:07 PM
In Topic: GE washer issues. 2nd rinse, water fill and agitation time.
15 April 2015 - 09:21 AM
Another 'trick' to get a normal rinse (at least on GEs) is to select the 'Fabric Softener' option on the dial (if available).
In Topic: GE fridge # PWE23KMDDES, SER #TD508201
11 April 2015 - 12:27 PM
Are you doing Warranty work? That S/N translates to October 2014. Well under a year old!
http://www.geapplian...se/10000722.htm
In Topic: GE Wall Oven (JTP45) --Element wire is missing
11 April 2015 - 12:20 PM
It helps to remove the door first. That's about 40% of the weight. (open door to first stop, lift door straight off - watch that hinges don't snap back on your fingers).
In Topic: GE refrigerator GSH22JSXJSS not cooling
10 April 2015 - 10:00 AM
Both. Post the Serial Number because there was a compensation program for certain models.
In Topic: Reversing position of washer and dryer?
05 April 2015 - 09:45 PM
I'd suggest using a hard 4" 90 elbow on the back of the dryer to keep the hose from kinking there like this one: http://www.homedepot...B90E4/100033952 . Maybe one on the wall or floor where the vent leaves the laundry room too.
