sll
Member Since 15 Nov 2006
Offline Last Active Sep 02 2011 02:33 PM
In Topic: Reconfigure Jenn-Air gas cooktop?
02 September 2011 - 10:33 AM
Thanks. That's what I figured.
-s
In Topic: Thermador self-cleaning problem
09 December 2006 - 11:35 AM
Understood, I will have the switch replaced.
Thanks again.
09 December 2006 - 11:16 AM
Paul, lifting the vent piping did the trick. Thanks again.
Steve
09 December 2006 - 11:02 AM
Paul, The clock display and the timer functions are working properly. When I try to self-clean, all indications on the clock (auto, end time) seem to be ok but heating never occurs.
s
09 December 2006 - 10:35 AM
Thanks Paul. If I disconnect the venting should I be able to manually activate the switch? If this doesn't correct the problem is the clock relay the probable cause. Is there a way to hardwire around the relay to see if it is faulty?
Thanks,
s
