rbmappltech
Member Since 01 Sep 2013
Offline Last Active Apr 19 2015 03:11 PM
#315238 RS263TDWP/XAA Samsung side by side not cooling well
Posted by rbmappltech on 11 March 2015 - 08:45 PM
You will need a new evap cover, and a heat probe for the evap heater to go into the drain hole. There is a tech note from Samsung about this problem. Since I am not ASC for Samsung I don't have the Tech Notes. When I do the above, I have not had any call backs yet. Make sure the Drain is not plugged, and check the drain tube in back of the Fridge to make that is not plugged up either.
