ballacm
Member Since 09 Sep 2013
Offline Last Active Sep 10 2013 12:53 PM
Whirlpool Duet Washer Starts, spins once, doesn't fill & drain pump turns on
09 September 2013 - 05:42 PM
My 3 year old whirlpool duet washer will power up, I can select a cycle, and start the machine.  The door locks when started and then the tub spins about 1 revolution and then the drain pump turns on.  No water enters the tub.
Before this started there was an error message F017 (I think) and the drain pump was running constantly at a very slow flow.  I found that the filter going into the pump was clogged with a sock.  Cleand out the filter plugged back in and everything seemed to be normal.  Then the issue above happened.  I think I've narrowed this down to the water level sensor?  Has anyone seen this before?
