sawyer33
Member Since 23 Sep 2013
Offline Last Active Dec 06 2014 06:58 AM
#275918 GE Advantium microwave not heating
Posted by sawyer33 on 30 November 2013 - 04:12 PM
Here is a photo of the bad magnetron
#275843 GE Advantium microwave not heating
Posted by sawyer33 on 29 November 2013 - 07:28 PM
I got it working again!
I bought a new magnetron. When I took out the “working” magnetron I had purchased I tested it against the new one and both tested good. I examined further and found that the “working” magnetron had a broken magnet on the front; this shows that a magnetron that tests good can still be bad. The new magnetron did the trick.
#269179 GE Advantium microwave not heating
Posted by sawyer33 on 23 September 2013 - 09:42 PM
I have a GE Advantium microwave SCB2000CBB03. The magnetron, diode, and the capacitor test ok with a voltmeter using suggested tests. The keyboard functions all work properly as does the speed bake (halogen). The microwave does not heat. The oven starts normally however there is not any humming initially or otherwise; the noise generated while running is from the oven cooling fan and the magnetron fan. The door opens properly for the magnetron fan. I checked all door safety and monitoring switches and all ok. All temperature switches are closed.
After running in microwave mode for three minutes, the transformer and capacitor are room temperature, the magnetron is slightly warm (98 degrees).
The microwave function used to interfere with the portable phone, now with the microwave operating the phone is fine.
I have no means to check the transformer as voltage output is too high. Is there another way to trouble shoot the transformer? Do you suspect the transformer or do you suspect another possible problem I failed to check?
Thanks!
