debsr
Member Since 24 Sep 2013
Offline Last Active Nov 06 2013 06:59 PM
In Topic: Washer Won't Fully Drain
05 November 2013 - 02:52 PM
Yes, I am having some functional issues.  The wash cycles are not processing normally and it feels like the water in the inner basket is increasing, as in not draining as it was previously.  I know this because the machine feels heavier than normal and I don't hear it draining through the outer hose as it did previously....
In Topic: Getting A GE Washer Mod# WWSE5240G0WW To Start
01 October 2013 - 05:47 PM
IT WORKED, IT WORKED, IT WORKED!!!!!!! THANK YOU SSSSSSSSSSSOOOOOOOOO MUCH!!!!!!
26 September 2013 - 01:47 PM
Ok, thank you for the advice and the link. I will try it and let you know what happens!
24 September 2013 - 09:37 AM
The lights stay on. If i change the knob to a different cycle, that cycle's button will light up. However the machine will not start....
