debsr
Member Since 24 Sep 2013
Offline Last Active Nov 06 2013 06:59 PM
Washer Won't Fully Drain
05 November 2013 - 10:00 AM
Hello!
I have a GE WWSe5240GOWW washer.  It is not completely draining the water from the outside of the drum (I can tell when there is water outside of the drum because the washer is heavy). The water is completely draining from inside the drum and completing the wash cycle, rinse, drain and spin, but all of the water is not completely draining from the entire machine. Can anyone help???
Getting A GE Washer Mod# WWSE5240G0WW To Start
24 September 2013 - 07:46 AM
My GE Washer Mod# WWSE5240G0WW will not start. I have power and everything lights up. However, when I press the start button, nothing happens. Does anyone know how I can fix this? I managed to get the panel off and it seems that I may be missing a part where the plastic lever behind the outer start button is not connecting with a small red button connected to the circuit board.  Can anyone help??
