rolloffman
Member Since 27 Sep 2013
Offline Last Active Oct 03 2013 03:35 PM
samsung WF203ANW ND error
30 September 2013 - 05:38 PM
I have a samsung wf203anw that recently started throwing nd error, I have taken it apart cleaned all the hoses anywhere that I could get at to see if it was clogged up. It was a little grungy, not bad likely due to too much soap, I also d/led the trouble shooting pdf and proceeded to go through all the tests everything was fine but when I went to test the pump I pushed the signal button to test it and nothing pressed it again and the same thing nothing, I pressed the button about 15 times and then it kicked on. So I thought the pump is bad, purchased a new pump and the same thing pressed the signal button  in quick test mode and nothing, pressed it a bunch of times and it kicked on once or twice. Any thoughts on whats wrong???, thank you in advance for any replys.
P.S I have noticed that I run a load it will come up nd, but if I go and turn it off right away and then select spin only it will drain and spin the load?????
