rcr286
Member Since 01 Oct 2013
Offline Last Active Oct 10 2013 09:01 AM
In Topic: Fisher & Paykel GWL10US help
04 October 2013 - 03:44 PM
No one has installed a fuse. I tracked all wires that were exposed and looked under housing covers last night and could not find anything. I should be able to check the resistance this weekend, so maybe it will confirm both pumps are bad.
03 October 2013 - 05:31 PM
Good to know. So, the quick and dirty question is "where is the fuse located?".
03 October 2013 - 03:49 PM
Thanks guys. Being that it is a newer pump, I'm surprised it is the culprit. I will look for the fuse, but would the controller be working at all if the fuse was blown? I don't have a multimeter nearby, so I am waiting on a friend to loan me one. I will check the ohms as RegUS_PatOff said.
Before going much further, would I even be getting the beeps and information that I am getting if the Display Module was out? Are there any other signs or test methods to find if the Motor Controller Module is the issue?
Thanks again.
