devilslettuce
Member Since 02 Oct 2013
Offline Last Active Jul 09 2014 12:23 PM
In Topic: Whirlpool WFW9400SW03 F73 Error
10 November 2013 - 08:27 PM
I do have a photo, its not the best shot ever but I do have it. Was trying to figure out how to post the image on here by uploading.
10 November 2013 - 12:15 PM
found it, bad connecton not on the CCU or MCU but rather F73 is a bad connection on the front panel control board.
 i can see where a technician even tried to repair the connector and put this name on a label.
ill repair and test
10 November 2013 - 11:59 AM
Yes indeed I do get the 3 beeps of death the moment i plug in.  Then F73 on screen,
i've opened the machine up and have ensured all connections on both control boards are connected. I did try removing the blue cable as well but same beeps and code. i'm going to move onto trying to remove the PCB's and verify ok connections on the boards.
In Topic: Bosch B22CS80SNS
05 October 2013 - 01:09 PM
This is an image of the freezer after 1 hour of running. not an overly large amount of icing but it is icing.
In Topic: GSL25JFPA BS. GE Refrigerator won't freeze
05 October 2013 - 09:52 AM
Sounds a lot like a Sealed System Failure, you may be out of luck on this one. Typically if you have a warm feezer and it does not get ice build up after a 30min to hour run time and the evap fan runs then this is the case unfortunately. If you have any images that may help if we can see the evap after an hour of run time.
