dwieder
Member Since 26 Nov 2006
Offline Last Active Sep 20 2013 08:03 AM
In Topic: Bosch SHE55M05UC Not Draining - can't access drain pump
16 March 2012 - 03:01 PM
I purchased a new drain pump for my
Bosch SHE55M05UC, I cannot figure out how to access the pump. I removed the toe kick but can still not get to the pump, please help. The instructions I received were incomplete. Also if anyone has the diagnostic codes for this model I'd appreciate sharing
In Topic: Whirlpool KUDP01ILBS3 Dishwasher blinking light Electronic Control
17 January 2012 - 06:27 PM
I'm still baffled if its a stuck key, why would it work for 1 minute after breaker reset and then stop.
Should I return my new electronic control assembly
17 January 2012 - 06:16 PM
Would you suggest going back to the old control board, as symptoms have not changes
17 January 2012 - 06:02 PM
Thank you
Is there anything I can do to verify this. (can't seem to get the diagnostics to work, perhaps I'm doing it wrong)
Then what to do, any way to fix, or do i need to replace entire front.
17 January 2012 - 05:56 PM
When light flashes I can press cancel and then cancel flashes but nothing else happens. If i press start and cancel together it drains, but then normal light continues to blink. Any suggestions
